| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays available RAM and filesystem space.
showfree [-m][-d][-k]
This hardware command displays the free RAM memory available for use by the management controller and the free disk space in the filesystem in megabytes. The available RAM is described as an absolute number of bytes and as a percentage of total. The available disk space is described as the filesystem, the mount point, the absolute number of bytes, and as a percentage of total.
The showfree command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the showfree command and their purposes.
This example shows how to display the available RAM and disk space in kilobytes with the showfree command.
FabMan@gateway_name->showfree -mdk Memory: 306564 kB 60.1% Filesystems: /dev/hda5 / 130168 kB 32.2% /dev/hda3 /var/log 8644 kB 55.6% /dev/hda2 /config 10763 kB 69.2% tmpfs /dev/shm 255000 kB 100.0% tmpfs /tmp 254004 kB 99.6% FabMan@gateway_name->
Gateway Administration, displaying free memory
