| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Sets the gateway instance.
setgwinstance instance|list
where instance is a number from 0 to 63.
When you configure multiple gateways, the gateways identify themselves to each other with a gateway instance number. No two gateways can have the same instance number.
Note - The setgwinstance command automatically stops and restarts the BridgeX manager.
Using the list option displays known gateways and their instance numbers.
The setgwinstance command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to set the gateway instance of the gateway to 3 using the setgwinstance command.
FabMan@gateway_name->setgwinstance 3 Stopping Bridge Manager.. [ OK ] Starting Bridge Manager. [ OK ] FabMan@gateway_name->
This example shows how to display the gateway instances of known gateways with the list option of the setgwinstance command.
FabMan@gateway_name->setgwinstance list Current GW instance: 3 FabMan@gateway_name->
