Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays VLANs.
showvlan [-h]
This hardware command displays the VLANs associated to the gateway connectors. The -h option provides help. This table describes each of the columns of the output
The showvlan command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the VLANs associated with all connectors using the showvlan command.
Note - Your output will differ from that in the example.
FabMan@gateway_name->showvlan Connector/LAG VLN PKEY ------------- --- ---- 0A-ETH-1 3 ffff 0A-ETH-1 0 ffff 0A-ETH-2 3 ffff 0A-ETH-2 0 ffff 0A-ETH-3 3 ffff 0A-ETH-3 0 ffff 0A-ETH-4 3 ffff 0A-ETH-4 0 ffff 1A-ETH-1 3 ffff 1A-ETH-1 0 ffff 1A-ETH-2 3 ffff 1A-ETH-2 0 ffff 1A-ETH-3 3 ffff 1A-ETH-3 0 ffff 1A-ETH-4 3 ffff 1A-ETH-4 0 ffff FabMan@gateway_name->
