| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspect the Data Cable Hardware
Inspect the Data Cable Connectors or Transceivers
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Note - These instructions are valid for InfiniBand and Ethernet data cables. Refer to Gateway Installation, assembling the optical fiber data cables, for instructions how to assemble InfiniBand and Ethernet data cables that require assembly.
Refer to Gateway Installation, assembling the optical fiber data cables.
Ensure that the L groove is up for the top row of receptacles, or that the L groove is down for the bottom row of receptacles.
Note - On some QSFP cable connectors, there is a retraction strap. Both the retraction strap and L groove indicate the reference surface for the connector. When installing QSFP cables in the top row receptacles (0A, 1A, 2A, and so on), ensure that the L groove and retraction strap are up. When installing QSFP cables in the bottom row receptacles (0B, 1B, 2B, and so on) ensure that the L groove and retraction strap are down. See Identify the Data Cable.
As you slide the connector in, the shell should be in the center of the QSFP receptacle.
Close hook-and-loop fasteners at bundles and securing hard points.
