| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Restricts host configuration of VNICs.
disallowhostconfig [-h]
This hardware command restricts the configuration of VNICs from the individual hosts of the InfiniBand fabric, effectively disabling Host Manual Mode. Consequently, Gateway Manual Mode becomes the default means of configuring VNICs. The -h option provides help.
The disallowhostconfig command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to restrict host configuration of VNICs with the disallowhostconfig command.
FabMan@gateway_name->disallowhostconfig Stopping Bridge Manager.. [ OK ] Starting Bridge Manager. [ OK ] FabMan@gateway_name->
