| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
InfiniBand Connector Status Window
Gateway Connector Status Window
InfiniBand Connector Parameters and Status
Gateway Connector Parameters and Status
I4 to Gateway Interface Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Hidden on the right side of the FM is the control panel. Clicking the more>> link opens the control panel and legend. This figure provides an example of the control panel.
The control panel has five checkboxes that enable you to select what aspect of the gateway is to be monitored. You can select to monitor:
Note - All checkboxes are enabled by default. By clearing the checkboxes that are not necessary for your monitoring needs, you reduce the load on the interface and optimize the operation of the FM.
Poll All Data – Selecting this checkbox enables all polling. Consequently, all checkboxes are selected. When all checkboxes are selected, the added resource demand on the management controller slows its ability to display the information.
Poll Switch – Selecting this checkbox enables you to monitor the status of the gateway hardware and the Subnet Manager. By checking this box, the System Info, Sensor Info, and Subnet Manager tabs of the status pane become active and are populated with information.
Poll I4 – Selecting this checkbox enables you to monitor the status of the I4 switch chip and the links its ports negotiate. By checking this box, the IB Performance and IB Port Map tabs of the status pane become active and are populated with information. Additionally, the Show Aggregate Bandwidth Chart link under the System Info tab becomes active.
Poll BX – Selecting this checkbox enables you to monitor the status of the BridgeX chips and the connections from its ports. You must also select the Poll Connectors checkbox to view the status of the BridgeX chips.
Poll Connectors – Selecting this checkbox enables you to monitor the status of the connectors on the gateway rear panel. By checking this box, the rear panel diagram becomes active and displays present connectors and their condition.
