| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays port status.
getportstatus connector|ibdev port
where:
connector is the name of the connector (0A to 15A, 0A-ETH, 1A-ETH, 0B to 15B).
Note - The subordinate names of the 10GbE connectors, 0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4, are also valid connector names.
ibdev is the InfiniBand device name (Switch, Bridge-0-0, Bridge-0-1, Bridge-1-0, Bridge-1-1)
port is the number of the port (1 to 36).
This hardware command returns the status of the specified connector or port of the switch chip.
The getportstatus command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the status of connector 9A with the getportstatus command.
Note - The parameters with the string Active indicate the current conditions.
FabMan@gateway_name->getportstatus 9A Port status for connector 9A Switch Port 14 Adminstate:......................Enabled LinkWidthEnabled:................1X or 4X LinkWidthSupported:..............1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkState:.......................Active PhysLinkState:...................LinkUp LinkSpeedActive:.................10.0 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps FabMan@gateway_name->
This example shows how to display the status of connector 0A-ETH-1 with the getportstatus command.
FabMan@gateway_name->getportstatus 0A-ETH-1 Port status for connector 0A-ETH-1 Bridge-0 Port Bridge-0-2 Adminstate.......................Enabled State............................Up Link state.......................Up Protocol.........................Ethernet Link mode........................XFI Speed............................10Gb/s MTU..............................9600 Tx pause.........................Global Rx pause.........................Global FabMan@gateway_name->
