| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Checks firmware integrity.
fwverify
This hardware command checks if the firmware installed is corrupted or has been tampered with. The command first makes a comparison of the installed RPM packages to a predefined list of what RPM packages should be installed for the given firmware version. This list was generated at the time of the firmware image build. The fwverify command then performs a verification for each installed package using the rpm --verify command.
Should the command find a missing, corrupt, or additional package or file, the command will display the package or file name, and its location in the filesystem. The conditions of the error are displayed as an 8-character string of flags, SM5DLUGT, where:
S – File size differs.
M – Mode (including permissions and file type) differs.
5 – MD5 sum differs.
D – Device major/minor number mis-match.
L – readlink(2) path mis-match.
U – User ownership differs.
G – Group ownership differs.
T – mtime differs.
. – Flag was not set (no error).
Note - The fwverify command might indicate that files in the /config/fwutils directory have changed. The error can safely be ignored.
The fwverify command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to verify the firmware integrity with the fwverify command.
FabMan@gateway_name->fwverify Checking all present packages: ........................................................................... OK Checking if any packages are missing: ........................................................................... OK Verifying installed files: ....................................................................... FAILED * Package nm2gw-phs-2.0.5-1.i386: S.5....T /etc/init.d/dcs . . . FabMan@gateway_name->
In this example, within the nm2gw-phs-2.0.5-1.i386 RPM package, the /etc/init.d/dcs file size differs, the MD5 sum differs, and the time differs
This example shows a successful verification.
FabMan@gateway_name->fwverify Checking all present packages: ........................................................................... OK Checking if any packages are missing: ........................................................................... OK Verifying installed files: ........................................................................... OK Checking FW Coreswitch: FW Version: 7.4.2200 OK PSID: SUNX2826_I40_002 OK Verifying image integrity OK Checking FW Bridge-0: FW Version: 8.6.2010 OK PSID: SUNX2826_BX0_006 OK Verifying image integrity OK Checking FW Bridge-1: FW Version: 8.6.2010 OK PSID: SUNX2826_BX1_006 OK Verifying image integrity OK FabMan@gateway_name->
