| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Queries InfiniBand fabric management attributes.
smpquery [-d][-D][-e][-G][-h][-v][-V][-C ca_name][-P ca_port][-t timeout] op lid|dr_path|guid [params]
where:
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
op is the supported operation.
lid is the local identifier.
dr_path is the directed path.
guid is the global unique identifier.
params is the parameter of the operation.
This InfiniBand command permits a subset of the standard SMP queries, including these:
Node information
Node description
Switch information
Port information
Output is in human-readable format.
Supported operations and parameters are as follows:
nodeinfo addr
nodedesc addr
portinfo addr [portnum]
switchinfo addr
pkeys addr [portnum]
sl2vl addr [portnum]
vlarb addr [portnum]
guids addr
where:
addr is the address.
portnum is the port number.
The smpquery command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the smpquery command and their purposes.
This example shows how to display node information for LID 15 with the smpquery command.
FabMan@gateway_name->smpquery nodeinfo 15 # Node info: Lid 15 BaseVers:........................1 ClassVers:.......................1 NodeType:........................Switch NumPorts:........................36 SystemGuid:......................0x0021283a8389a0a3 Guid:............................0x0021283a8389a0a0 PortGuid:........................0x0021283a8389a0a0 PartCap:.........................8 DevId:...........................0xbd36 Revision:........................0x000000a0 LocalPort:.......................1 VendorId:........................0x0002c9 FabMan@gateway_name->
smpquery man page
