Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays chassis FRU information.
showfruinfo
This hardware command displays the contents of the chassis FRU ID registers.
The showfruinfo command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the chassis FRU ID registers with the showfruinfo command.
FabMan@gateway_name->showfruinfo Sun_Man1R: UNIX_Timestamp32 : Fri Dec 14 01:24:28 2012 Sun_Fru_Description : ASSY,NM2-GW Vendor_ID_Code : 11 E1 Vendor_ID_Code_Source : 01 Vendor_Name_And_Site_Location : 4577 CELESTICA CORP. SAN JOSE CA US Sun_Part_Number : 5111402 Sun_Serial_Number : 0110SJC-1010NG0040 Serial_Number_Format : 4V3F1-2Y2W2X4S Initial_HW_Dash_Level : 03 Initial_HW_Rev_Level : 50 Sun_Fru_Shortname : NM2 gateway Sun_Hazard_Class_Code : Y Sun_SpecPartNo : 885-1655-01 Sun_FRU_LabelR: Sun_Serial_Number : 1013AK208D FRU_Part_Dash_Number : 541-4188-01 FabMan@gateway_name->
