| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Traces the InfiniBand path.
ibtracert [-d][-D][-G][-h][-m mlid][-s smlid][-v][-V][-C ca_name][-P ca_port][-t timeout][lid|dr_path|guid [startlid [endlid]]]
where:
mlid is the multicast LID.
smlid is the Subnet Manager LID.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
lid is the local identifier.
dr_path is the directed path.
guid is the global unique identifier.
startlid is the starting LID for a range.
endlid is the ending LID for a range.
This InfiniBand command uses SMPs to trace the path from a source GID or LID to a destination GID or LID. Each responding hop in the path is displayed. The -m option enables multicast path tracing between source and destination nodes.
The ibtracert command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibtracert command and their purposes.
This example shows how to display the path from LID 25 to LID 24 with the ibtracert command.
Note - The output for your InfiniBand fabric will differ from that in the example.
FabMan@gateway_name->ibtracert 15 14
From switch {0x00212856cd22c0a0} portnum 0 lid 15-15 "SUN IB QDR GW switch mnm34-97"
[1] -> ca port {0x00212856cd22c042}[2] lid 14-14 "SUN IB QDR GW switch mnm34-97 Bridge 1"
To ca {0x00212856cd22c040} portnum 2 lid 14-14 "SUN IB QDR GW switch mnm34-97 Bridge 1"
FabMan@gateway_name->ibtracert man page
