| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Manages the state and link speed of an InfiniBand port.
ibportstate [-d(ebug)][-D(irect)][-e(rr_show)][-G(uid)][-h][-s smlid][-v(erbose)][-C ca_name][-P ca_port][-t(imeout) timeout][-M(key) m_key] lid|dr_path|guid port [op]
where:
smlid is the Subnet Manager LID.
topology is the topology file.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
m_key is the management key (16 hexadecimal digits).
lid is the local identifier.
dr_path is the directed path.
guid is the global unique identifier.
port is the port being validated.
op is the operation to perform on the port:
enable
disable
reset
speed number (where number is 1 for SDR, 2 for DDR, and 4 for QDR)
query (default)
This InfiniBand command queries the logical and physical state of an InfiniBand port. The command can return the link width and speed of a switch chip port, as well as enabling, disabling, or resetting the port. The command can also set the link speed of any InfiniBand port.
Note - State changes made with the ibportstate command are not recognized by the disableswitchport, enableswitchport, or listlinkup commands.
Note - Speed changes are not affected until the port undergoes link renegotiation. Additionally, speed values are additive for enabling. For example, speed 7 is 2.5, 5.0, and 10.0 Gbit/sec.
The ibportstate command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibportstate command and their purposes.
This example shows how to query the state and link speed of LID 15, port 23 with the ibportstate command.
FabMan@gateway_name->ibportstate 15 23 PortInfo: # Port info: Lid 15 port 23 LinkState:.......................Active PhysLinkState:...................LinkUp LinkWidthSupported:..............1X or 4X LinkWidthEnabled:................1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedActive:.................10.0 Gbps Peer PortInfo: # Port info: Lid 15 DR path slid 15; dlid 65535; 0,23 LinkState:.......................Active PhysLinkState:...................LinkUp LinkWidthSupported:..............1X or 4X LinkWidthEnabled:................1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedActive:.................10.0 Gbps FabMan@gateway_name->
