| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Maps between switch chip ports and QSFP connectors.
dcsport [-guid guid|-type DCS-gw -ibdev ibdev] -port port|-connector connector|-printconnectors|-printinternal
where:
guid is the global unique identifier.
ibdev is the InfiniBand device name (Switch, Bridge-0-0, Bridge-0-1, Bridge-1-0, Bridge-1-1)
port is the number of the port (1 to 36).
connector is the name of the connector (0A to 15A, 0A-ETH, 1A-ETH, 0B to 15B).
Note - The subordinate names of the 10GbE connectors, 0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4 are also valid connector names.
This hardware command displays the mapping between I4 switch chip ports, BridgeX chip ports, and QSFP connectors. You can specify either a port or a connector.
The dcsport command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the dcsport command and their purposes.
Note - If no guid or ibdev are specified, the command defaults to the local I4 switch chip or BridgeX chips, inferred by the port number or connector name.
This example shows how to display the mapping for connector 0A-ETH with the dcsport command.
FabMan@gateway_name->dcsport -connector 0A-ETH
Connector 0A-ETH maps to:
0A-ETH-1 Bridge-0-1 port 0A-ETH-1
0A-ETH-2 Bridge-0-1 port 0A-ETH-2
0A-ETH-3 Bridge-0-0 port 0A-ETH-3
0A-ETH-4 Bridge-0-0 port 0A-ETH-4
