| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Reads QSFP cable information.
connector name present|portstate|info|dump [-h]
where name is the name of the connector (0A to 15A, 0A-ETH, 1A-ETH, 0B to 15B).
This hardware command performs a pass-fail test to verify that an InfiniBand cable is connected to a particular connector and to the switch chip port that the link routes. The command can also read the data registers of the cable and report FRU ID information.
The connector command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the connector command and their purposes.
This example shows how to display the FRU ID information for connector 1A with the connector command.
FabMan@gateway_name->connector 1A info Cable connector 1A present Indentifier: QSFP Connector type: Copper pigtail Vendor: Amphenol Vendor OUI: 415048 Partnumber: 568400005 Revision: C Serialnumber: APF08510050019 Date: 081219 FabMan@gateway_name->
