Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays NAN flash drive information.
showdisk
This hardware command displays comprehensive status and life information about the NAN flash drive within the management controller. This drive is the repository of the firmware, operating system, and filesystem of the management controller.
The NAN flash technology is limited to a finite number of data erases to memory cells, in that each erase to the cell “ages” the cell. Once the age limit is exceeded, the memory cell is “dead” as it can no longer reliably store data. To extend the life of a NAN flash drive, when data is written, it is written to new locations throughout the group, and the file allocation table is accordingly updated.
For example, instead of erasing and writing data to the same memory cell over the course of five writes, the data is written to five different memory cells, one per each write. The file allocation table is updated on each write to point to the memory cell with the most current data. Though the previous memory cells still contain data, they are considered empty and are not erased until they are needed to receive different data writes in the future.
The output of the showdisk command includes:
FRUID type information – Model, serial number, and firmware version.
SMART capabilities – Both supported and enabled.
Average age – The average number of erases to any given memory cell within a group.
Number of block erases – The total number of erases to all memory cells in a group.
Number of blocks – Similar to clusters in hard drives, the blocks are the smallest group of memory that can be erased.
Estimated life used – A calculated percentage of memory cells that are dead or soon to be dead, based upon current erasing behaviors and a finite number of erases per memory cell.
Estimated life remaining – 100% minus estimated life used.
The showdisk command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to information about and status of the NAN flash drive with the showdisk command.
FabMan@gateway_name->showdisk Device Model : 512MB NANDrive Serial Number : 0000000000A1PsB87FAa Firmware Version: ND B642J SMART supported : yes SMART enabled : yes Average age (4 groups): group 0: 12817 group 1: 533 group 2: 715 group 3: 954 Block erase count (4 groups): group 0: 12782181 group 1: 532378 group 2: 713173 group 3: 952668 Total : 14980400 Total physical blocks: 4096 Estimated Life Usage : 12.817 % Estimated Remaining Life: 87.183 % FabMan@gateway_name->
Gateway Administration, displaying flash drive information
