| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Queries InfiniBand port counters.
perfquery [-d][-e][-G][-h][-a][-l][-r][-R][-v][-V][-C ca_name][-P ca_port][-t timeout][lid|guid [[port][reset_mask]]]
where:
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
lid is the local identifier.
guid is the global unique identifier.
port is the port being queried.
reset_mask is the two-byte mask.
This InfiniBand command uses the performance management GMPs to acquire the PortCounters or PortExtendedCounters from the Performance Manager agent at the node or port specified.
Note - The data values retrieved from PortCounters and PortExtendedCounters are represented as octets divided by 4.
Note - Providing a port value of 255 ensures that the operation is performed on all ports.
The perfquery command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the perfquery command and their purposes.
This example shows how to display all port counters for LID 15, port 23 with the perfquery command.
FabMan@gateway_name->perfquery 15 23 # Port counters: Lid 15 port 23 PortSelect:......................23 CounterSelect:...................0x1b01 SymbolErrors:....................0 LinkRecovers:....................0 LinkDowned:......................0 RcvErrors:.......................0 RcvRemotePhysErrors:.............0 RcvSwRelayErrors:................0 XmtDiscards:.....................0 XmtConstraintErrors:.............0 RcvConstraintErrors:.............0 LinkIntegrityErrors:.............0 ExcBufOverrunErrors:.............0 VL15Dropped:.....................0 XmtData:.........................20232 RcvData:.........................20232 XmtPkts:.........................281 RcvPkts:.........................281 FabMan@gateway_name->
perfquery man page
