| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Switch Chip Port to QSFP Connectors and Link LED Routes
QSFP Connectors and Link LEDs to Switch Chip Port Routes
Signal Route Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Global unique identifiers (GUIDs) are unique 64-bit strings that identify nodes such as switches and channel adapters. For the Sun Datacenter InfiniBand switches and this gateway, GUIDs are modified to identify the node's role and location. This table describes the GUID's structure.
The five fields of the GUID are described as follows:
MAC – Bits 63 through 16 are the Machine Allocation Code (MAC) address. A standard for network components, the MAC address is typically provided by manufacturers in a 6-byte, colon delimited string. For example, 00:11:22:33:44:55.
Type – Bits 15 through 12 is the type of board on which the node resides.
Pos – Bits 11 through 8 identify the position of the board within the gateway.
Device – Bits 7 through 4 identify which device on the board has that node.
Num – Bits 3 through 0 are numbers reserved for the programs which modify the GUID. In most occurrences, the value is 0x2.
This table provides values for Type, Pos, Device.
For example, given this output from the ibnodes command:
Ca : 0x0021283bad45c000 ports 2 "SUN IB QDR GW switch gw-2 Bridge 0"
The GUID is 0x0021283bad45c000 or 0021283BAD45 C 0 0 0. Using the information provided in this topic:
The MAC address is 0x0021283BAD45 or 00:21:28:3B:AD:45.
The type is 0xC, or a gateway.
The position is 0x0.
The device is 0x0, or BridgeX chip 0.
The number is 0.
Gateway Reference, ibnetdiscover command
Gateway Reference, ibnodes command
Gateway Reference, ibswitches command
Gateway Reference, ibhosts command
