| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Manages the Subnet Manager nodes file.
smnodes add IP_address [IP_address ...]|delete IP_address [IP_address ...]|list
where IP_address is the IP address of the Subnet Manager nodes.
This hardware command adds to, deletes from, or lists the Subnet Manager nodes of the Subnet Manager nodes file. The file is used when partitioning the InfiniBand fabric, to make partition managers aware of each other.
The smnodes command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to list the Subnet Manager nodes of the file with the smnodes command.
FabMan@gateway_name->smnodes list 123.45.67.89 123.45.67.90 FabMan@gateway_name->
