Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Sets the Subnet Manager routing algorithm.
setsmrouting fattree|minhop|list
This hardware command sets the routing algorithm of the Subnet Manager within the management controller. By default, the routing algorithm is Fat Tree, which is ideal for routing between spine switches. For routing between leaf switches, you might consider the Min Hop routing algorithm. The list option provides a listing of the Subnet Manager settings in respect to priority, controlled handover, subnet prefix, M_Key, and routing algorithm.
The setsmrouting command writes the value of engine to the routing_engine parameter of the configuration file.
Note - You must stop or disable the Subnet Manager before using the setsmrouting command. See disablesm Command.
The setsmpriority command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to set the Min Hop routing algorithm with the setsmrouting command.
FabMan@gateway_name->setsmrouting minhop Current SM settings: smpriority 0 controlled_handover FALSE subnet_prefix 0xfe80000000000000 M_Key 0xabbababe0001 Routing engine minhop FabMan@gateway_name->
Gateway Administration, setting the routing algorithm
