| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays VNIC information.
showvnics
This hardware command displays VNICs and their parameters. The list of VNICs is in ascending order, with priority in this sequence:
Connector number
GUID
State
MAC address
This table describes each of the columns of the output
The showvnics command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the state of the VNICs with the showvnics command.
Note - Your output will differ from that in the example.
FabMan@gateway_name->showvnics ID STATE FLG IOA_GUID NODE IID MAC VLN PKEY GW --- -------- --- ----------------------- ---------- ---- ----------------- --- ---- -------- 9 UP N 00:03:BA:00:01:00:E3:71 mnm34-60 0000 02:02:02:02:02:07 NO 9002 0A-ETH-1 8 UP N 00:03:BA:00:01:00:E3:72 mnm34-60 0000 02:02:02:02:02:06 NO 9002 0A-ETH-1 4 UP N 00:03:BA:00:01:00:E3:71 mnm34-60 0000 02:02:02:02:02:03 NO ffff 0A-ETH-2 5 UP N 00:03:BA:00:01:00:E3:71 mnm34-60 0002 02:02:02:02:02:04 NO ffff 0A-ETH-2 3 DISABLED N 00:03:BA:00:01:00:E3:71 mnm34-60 0000 02:02:02:02:02:02 NO ffff 0A-ETH-2 6 UP N 00:03:BA:00:01:00:E3:72 mnm34-60 0000 02:02:02:02:02:05 NO ffff 0A-ETH-2 7 UP N 00:03:BA:00:01:00:E3:71 mnm34-60 0000 02:02:02:02:02:01 NO ffff 0A-ETH-3 FabMan@gateway_name->
