PDU Physical Specifications
Table 2 PDU Physical Specifications
Depth
Width
Power input lead cord nominal length
4 m / 13.12 ft.
Weight (including cords)
Low-voltage PDUs for North and South
America, Japan, and Taiwan:
13.25 kg / 29.21 lbs
15.00 kg / 33.07 lbs
16.75 kg / 36.93 lbs
13.60 kg / 29.98 lbs
15.70 kg / 34.61 lbs
17.80 kg / 39.24 lbs
High-voltage PDUs for EMEA and
APAC:
13.10 kg / 28.88 lbs
14.70 kg / 32.41 lbs
16.30 kg / 35.94 lbs
16.10 kg / 35.49 lbs
20.60 kg / 45.42 lbs
25.15 kg / 55.45 lbs
Note -
1 to 1.5 m (3.3 to 4.9 ft.) of the cords will be routed within the rack
cabinet, so the site's AC power receptacle must be within 2m (6.6 ft.) of the
rack.
