Enable and Configure SNMP (Original PDU)
Use the HTML interface to enable SNMP, specify SNMP community hosts, and set
repeating SNMP trap durations.
Access the PDU metering unit from a system on the network.
See Access a Metering Unit on the Network (Original PDU).
Click on the Net Configuration link and log in as an admin user.
You are prompted to log in as an admin user. By default, both the admin
user name and password is admin.
Scroll down the page until you see the SNMP heading.
Click the SNMP Enable checkbox to enable SNMP.
If desired, you can disable HTTP access to the PDU by deselecting the HTTP
enable checkbox located just above the SNMP heading.
![Caution Caution](graphics/caution.gif) | Caution -
If you disable HTTP, you are no longer be able to log in to the HTML
interface using a web browser. To re-enable HTTP access, you must use
your SNMP agent software. Refer to your SNMP agent documentation or the
Solaris snmpset(1M) man page for more
information.
Under the Trap Host Setup heading, define up to 10 SNMP hosts.
Once configured, the metering unit sends SNMP traps to these hosts. For
each host, type in the IP address and the
SNMP community name. An SNMP community name identifies which
SNMP group the host belongs.
Provide values to the repeating trap settings.
Here is a description of these repeating trap settings.
The number of seconds between repeating the KeepAlive
trap.
0 - 60
Repeating Time for Traps
s between sending trap messages to SNMP
hosts.
0 - 60
Number of traps
The number of times the same trap can repeated to the
same host.
0 -255
Click the Submit button to enable these SNMP settings.
