Go to main content
Oracle® Rack Cabinet 1242 Power Distribution Units User's Guide
Exit Print View
Updated: March 2018
View Status Information on the LCD Screen (Enhanced PDU)
When the PDU metering unit resets or powers on, you can view network and firmware version level information on the LCD screen.
  • Press the Select Attribute button until the PDU information appears.
    image:Figure showing an example of the PDU information on the LCD                                 screen.
    The screen displays the following information:
    HW: x.x        FW:x.x
    DHCP: OFF (or ON)
    MAC: xx-xx-xx-xx-xx-xx
    IP: xxx.xxx.xxx.xxx
    SUB:xxx.xxx.xxx.xxx
    GATW:xxx.xxx.xxx.xxx
    DNS: xxx.xxx.xxx.xxx
    The following table describes the LCD screen information.
    LCD Text
    Description
    HW
    Version of the PDU hardware.
    FW
    Version of the PDU firmware.
    DHCP
    Displays ON, when DHCP is enabled, and OFF when DHCP is disabled. See Connect an Original PDU to a DHCP Network for more information about DHCP.
    MAC
    MAC address of the metering unit.
    IP
    IP address of the metering unit.
    • If DHCP is OFF, the IP address is an internally stored static address.
    • If DHCP is ON, the IP address is set by the DHCP server.
    SUB NET MASK
    IP subnet netmask.
    GATEWAY
    IP address of the gateway router.
    DNS
    IP address of the DNS server of the metering unit.
