Restore the PDU to Factory Default Settings (Original PDU)
If you need to correct a configuration error, or you want to clear the PDU before
moving it to a different rack, you can restore the PDU metering unit back to its
factory settings.
After restoring the unit, all network and configuration settings reset back to
their default values (for example, admin is the only user and the IP address returns
to the default value). All settings that you set for your environment are
lost.
Note -
After restoring the PDU metering unit back to its factory settings, you must
reconnect it to the network. See
Connecting PDUs to the Network for
instructions.
Log in to the PDU metering unit.
See Access a Metering Unit on the Network (Original PDU).
Click on the Net Configuration link and log in as an admin user.
See Login Information.
Scroll down the page until you see the Factory-Reset heading.
Click the Submit button to restore the PDU metering unit back to its default
factory settings.
