The PDU metering unit supports Simple Network Management Protocol (SNMP). SNMP provides the ability to send traps, or notifications, when one or more conditions have been met. If you enable SNMP, the metering unit can send and receive traps to and from SNMP agents on the network.
![]() | Caution - Do not place more than three get commands in a single SNMP request. Additional get commands might cause the PDU to experience a network hang. |
