You can download updates of the PDU metering unit firmware from the Downloads web site.
![]() | Caution - When updating the firmware, you must update both the metering unit firmware and the HTML interface pages. Failure to update the HTML pages causes certain pages of the interface not to display, which renders the web interface unusable. |
To locate the latest PDU firmware, search the Download Center for the Oracle Rack 1242. Follow the instructions on the web site to download the firmware.
If the download is not in a ZIP file, make sure you download both the metering unit firmware (MKAPP_Vx.x.dl) and the HTML interface files (HTML_Vx.x.dl).
The downloaded ZIP file contains two update files:
If the ZIP file also contains a text file, review it for any additional information about the firmware updates.
You are prompted to log in as an admin user. By default, both the admin user name and password is admin.
After updating the firmware, you are prompted to update the HTML interface.
See View Module Information (Original PDU) for instructions on viewing the firmware revision level.
