PDU Electrical Specifications
The following tables describe the PDU electrical specifications, including the
number and type of connectors and receptacles.
Table 3 Specifications for North and South America, Japan, and Taiwan Low-Voltage
Single Phase PDUs
Number of Inputs
2
3
3
Source Voltage
200-240V
200-240V
200-240V
Frequency
50/60 Hz
50/60 Hz
50/60 Hz
Max Line Current
24A
24A
36.8
Phase Current
N/A
N/A
N/A
Nominal Power Rating
10KVA
15KVA
22KVA
Recommended Circuit Breaker
30A
30A
50A
Outlets
42 x C13 6 x C19
42 x C13 6 x C19
42 x C13 6 x C19
Outlet Groups
6
6
6
Max Group Current
20A
20A
20A
Output Voltage
200-240V
200-240V
200-240V
Data Centre Receptacle
1ph 2W + ground 30A NEMA L6-30
Table 4 Specifications for North and South America, Japan, and Taiwan Low-Voltage
Three Phase PDUs
Number of Inputs
1
1
2
3
3
Source Voltage
200-220V
200-220V
200-220V
200-220V
200-220V
Frequency
50/60 Hz
50/60 Hz
50/60 Hz
50/60 Hz
50/60 Hz
Max Line Current
24A
40A
34.6A
24A
34.6A
Phase Current
13.85A
23A
20A
13.85A
20A
8.6KVA
15KVA
24KVA
26KVA
37KVA
30A
50A
50A
30A
50A
Outlets
42 x C13 6 x C19
42 x C13 6 x C19
42 x C13 6 x C19
42 x C13 6 x C19
42 x C13 6 x C19
Outlet Groups
6
6
6
6
9
Max Group Current
14A
20A
20A
14A
20A
Output Voltage
200-240V
200-240V
200-240V
200-240V
200-240V
3ph 3W + ground 30A IEC60309 NEMA L21-30P
3ph 3W + ground 60A IEC60309
Table 5 Specifications for EMEA and APAC High-Voltage Single Phase PDUs
Number of Inputs
2
3
Source Voltage
200-240V
200-240V
Frequency
50/60 Hz
50/60 Hz
Max Line Current
25A
32A
Phase Current
25A
32A
10KVA
15KVA
30A
30A
Outlets
42 x C13 6 x C19
42 x C13 6 x C19
Outlet Groups
6
6
Max Group Current
20A
20A
Output Voltage
200-240V
200-240V
1ph 2W + ground 32A IEC60309 3P 6H 230V
Table 6 Specifications for EMEA and APAC High-Voltage Three Phase PDUs
Number of Inputs
1
1
2
3
3
Source Voltage
220/380 - 240/415VAC 3Ø
Frequency
50/60 Hz
50/60 Hz
50/60 Hz
50/60 Hz
50/60 Hz
Max Line Current
16A
21A
16A
16A
18A
Phase Current
16A
21A
16A
16A
18A
11KVA
15KVA
24KVA
33KVA
37KVA
16/20A
25A
25A
16/20A
25A
Outlets
42 x C13 6 x C19
42 x C13 6 x C19
42 x C13 6 x C19
42 x C13 6 x C19
42 x C13 6 x C19
Outlet Groups
6
6
6
6
9
Max Group Current
20A
20A
18A
16A
18A
Output Voltage
220-240V
220-240V
220-240V
220-240V
220-240V
3ph 4W + ground 16A IEC60309 5P 6h 400V
3ph 4W + ground 32A IEC60309 5P 6h 400V
