Skipping Reference for a Deal
Procedure
To skip reference for a deal:
- Ensure that the Select Reference zone is expanded in the Deal Information screen.
Click the Skip Reference button
in the top right corner of the Select Reference zone.
A message appears confirming whether you want to skip the reference.
Click OK.
The reference is skipped.Tip: Alternatively, you can skip reference by clicking the check box corresponding to the Skip Reference field in the Deal zone of the Deal Information screen while defining a deal.
Related Topics
| For more information on... | See... |
| Select Reference zone | Select Reference |
| Deal Information page | Deal Information |
| Deal zone | Deal |
