Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Identify All Switches in the Fabric
Identify All HCAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display the Link Status of a Node
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Display the InfiniBand Fabric Configuration
Display the InfiniBand Fabric Partition Configuration
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Exchange Master Fabric Director Status
Partitioning the InfiniBand Fabric
Remove User Partitions for Firmware Downgrades
Determine Partitions and P_Keys
Add or Remove a Port From a Partition
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
To help ascertain the health of a node, the perfquery command displays the performance, error, and data counters for that node.
# perfquery lid port
where:
lid is the LID of the node.
port is the port of the node.
Note - If a port value of 255 is specified for a switch node, the counters are the total for all switch ports.
For example:
Note - The output in the example is just a portion of the full output.
# perfquery 15 28 # Port counters: Lid 15 port 28 PortSelect:......................28 CounterSelect:...................0x1b01 SymbolErrors:....................0 . . . VL15Dropped:.....................0 XmtData:.........................33791184 RcvData:.........................33789168 XmtPkts:.........................469322 RcvPkts:.........................469294 #
Switch Reference, perfquery command
