Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Identify All Switches in the Fabric
Identify All HCAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display the Link Status of a Node
Display Low-Level Detailed Information About a Node
Display the InfiniBand Fabric Configuration
Display the InfiniBand Fabric Partition Configuration
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Exchange Master Fabric Director Status
Partitioning the InfiniBand Fabric
Remove User Partitions for Firmware Downgrades
Determine Partitions and P_Keys
Add or Remove a Port From a Partition
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
The smpquery command can provide very detailed information about a port.
# smpquery portinfo lid port
where:
lid is the LID of the node.
port is the port of the node.
For example, to see detailed information about port 23 on the switch with LID 15, type.
Note - The output in the example is just a portion of the full output.
# smpquery portinfo 15 28 # Port info: Lid 15 port 28 Mkey:............................0x0000000000000000 GidPrefix:.......................0x0000000000000000 Lid:.............................0x0000 SMLid:...........................0x0000 CapMask:.........................0x0 DiagCode:........................0x0000 MkeyLeasePeriod:.................0 LocalPort:.......................28 LinkWidthEnabled:................1X or 4X LinkWidthSupported:..............1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkState:.......................Active PhysLinkState:...................LinkUp LinkDownDefState:................Polling ProtectBits:.....................0 LMC:.............................0 . . . SubnetTimeout:...................0 RespTimeVal:.....................0 LocalPhysErr:....................8 OverrunErr:......................8 MaxCreditHint:...................85 RoundTrip:.......................16777215 #
Switch Reference, smpquery command
