Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Identify All Switches in the Fabric
Identify All HCAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display the Link Status of a Node
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Display the InfiniBand Fabric Configuration
Display the InfiniBand Fabric Partition Configuration
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Exchange Master Fabric Director Status
Partitioning the InfiniBand Fabric
Remove User Partitions for Firmware Downgrades
Determine Partitions and P_Keys
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
You can add or remove one or more ports from the partition at one time.
# smpartition start #
# smpartition add -n partition_name|-pkey p_key -port port|ALL|ALL_CAS|ALL_SWITCHES|ALL_ROUTERS|SELF [-m member]
where:
partition_name is the identifier of the InfiniBand partition.
p_key is the partition key (1 – 7fff).
port is the GUID of the port, or the special parameter, to add:
ALL – All of the CAs, switches, and routers in the InfiniBand fabric.
ALL_CAS – All CAs in the InfiniBand fabric.
ALL_SWITCHES – All switches.
ALL_ROUTERS – All routers.
SELF – The Master Subnet Manager.
member is the membership type (full, limited, or both) for the port.
For example:
# smpartition add -n testpartition -port 00212800013e9313 00212800013e9314 00212800013e93f7 #
# smpartition remove -n partition_name|-pkey p_key -port port|ALL|ALL_CAS|ALL_SWITCHES|ALL_ROUTERS|SELF
where:
port is the GUID of the port, or the special parameter, to remove:
For example:
# smpartition remove -n testpartition -port 00212800013e9314 #
# smpartition list modified # Sun DCS IB partition config file # This file is generated, do not edit #! version_number : 13 Default=0x7fff, ipoib : ALL_CAS=full, ALL_SWITCHES=full, SELF=full; SUN_DCS=0x0001, ipoib : ALL_SWITCHES=full; testpartition = 0x0005,defmember=full: 0x00212800013e9313, 0x00212800013e93f7; #
# smpartition commit #
