Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Identify All Switches in the Fabric
Identify All HCAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display the Link Status of a Node
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Display the InfiniBand Fabric Configuration
Display the InfiniBand Fabric Partition Configuration
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Exchange Master Fabric Director Status
Partitioning the InfiniBand Fabric
Remove User Partitions for Firmware Downgrades
Determine Partitions and P_Keys
Add or Remove a Port From a Partition
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Note - After creating user partitions, consider modifying the default partition to limited membership for CAs and disabling IPoIB. The reason being that nodes with full membership in different user partitions can communicate with each other through the default partition. See Modify a Partition or Port for an example.
# smpartition start #
# smpartition create -n partition_name -pkey p_key[-flag [ipoib, mtu mtu, rate rate, sl sl, scope scope]][-m defmember]
where:
partition_name is the identifier of the InfiniBand partition.
p_key is the partition key (1 – 7fff or default).
mtu is the value of the MTU.
rate is the throughput of a link (link width + link speed) in Gbps from 2.5, 5, 10, 20, 30 to a maximum of 40.
sl is the service level.
scope is the multicast address scope value (0 – F).
Note - The mtu, rate, sl, and scope parameters are for the multicast group created when ipoib (IP over InfiniBand) is configured for the partition.
defmember is the default membership type (full, limited, or both) for the partition.
Note - If ports are added to the partition without specifying the membership type, the default membership type is applied to the port
For example:
# smpartition create -n testpartition -pkey 5 -m full #
# smpartition list modified # Sun DCS IB partition config file # This file is generated, do not edit #! version_number : 13 Default=0x7fff, ipoib : ALL_CAS=full, ALL_SWITCHES=full, SELF=full; SUN_DCS=0x0001, ipoib : ALL_SWITCHES=full; testpartition = 0x0005,defmember=full: #
If you want to add GUIDs, see Add or Remove a Port From a Partition.
If you want to modify the configuration, see Modify a Partition or Port.
If you want to delete the configuration altogether, see Delete a Partition.
Otherwise, go to Step 6.
# smpartition commit #
