Available Software Release Packages
Downloads on My Oracle Support are grouped by product family, then product, then
version. The version contains one or more downloads (patches).
For servers and blades, the pattern is similar. The product is the server. Each server
contains a set of releases. These releases are not true software product releases, but
rather are releases of updates for the server. These updates are called software
releases and comprise several downloads, all tested together. Each download contains
firmware, drivers, or utilities.
My Oracle Support has the same set of download types for this server family as shown
in the following table. The same firmware and software can also be downloaded using
Oracle System Assistant.
Oracle Server X5-4 SW version –
Firmware Pack
All the system firmware, including Oracle ILOM, BIOS, and option
card firmware.
You need the latest firmware.
OS Pack
An OS Pack is available for each supported operating system
version. Each OS Pack includes a package of all tools, drivers, and
utilities for that version of the OS.
Software includes Oracle Hardware Management Pack and LSI MegaRAID
software.
For the Windows OS, this OS Pack also includes Intel Network
Teaming and Install Pack.
You need to update OS-specific drivers, tools, or
utilities.
All Packs
Includes the Firmware Pack, all OS Packs, and all
documents.
This pack does not include Oracle VTS or the Oracle System
Assistant image.
You need to update a combination of system firmware and
OS-specific software.
Diagnostics
Oracle VTS diagnostics image.
You need the Oracle VTS diagnostics image.
Oracle System Assistant recovery and ISO update image.
You need to manually recover or update Oracle System
Assistant.
Each of the downloads is a zip file that contains a ReadMe file and a set of
subdirectories containing firmware or software files. The ReadMe file contains details
on the components that have changed since the prior software release and the bugs that
have been fixed.
