Installing the Server Into a Rack
This section describes safety precautions and provides instrucions for how to install the
server into a rack using the rail assembly in the rackmount kit.
Review safety precautions.
Review the compatibility requirements for your rack.
Install mounting brackets onto the server.
Attach the tool-less slide-rail assembly to the rack.
Install the server into the slide-rail assembly.
(Optional) Install the cable management arm for routing server cables.
Verify that the slide-rails and cable management arm are working correctly.
