Install Cable Management Arm
This procedure provides instructions for attaching the optional cable management
arm (CMA) to the back of the server.
Unpack the CMA parts.
Take the CMA to the back of the equipment rack and ensure that you have adequate room to work
around the back of the server.
Note -
References to “left” or “right” in this procedure assume that you are
facing the back of the equipment rack.
Insert the CMA mounting bracket connector into the right slide-rail until the connector locks
into place with an audible click.
1
2
Right slide-rail
Insert the right CMA slide-rail connector into the right slide-rail assembly until the
connector locks into place with an audible click.
1
2
Right slide-rail
Insert the left CMA slide-rail connector into the left slide-rail assembly until the connector
1
2
Left slide-rail
Install, route, and dress the cables to the server.
Note -
Instructions for installing the server cables are provided in the
Cabling the Server section.
If required, attach the cable hooks and loop straps to the CMA, and press them into place to
secure the cables.
Note -
Cable hooks and loop straps are preinstalled on the CMA. Perform this step if you need to
reinstall cable hooks and straps on the CMA.
For best results, place three cable straps, evenly spaced, on the rear-facing side of the CMA
and three cable straps on the side of the CMA nearest the server.
1
CMA cable strap
2
CMA arm
