Install Mounting Brackets
This procedure provides instructions for securing the mounting brackets to both sides of the
server.
Position a mounting bracket against the chassis so that the slide-rail lock is
at the server front, and the five keyhole openings on the mounting bracket are
aligned with the five locating pins on the side of the chassis.
Note -
The mounting brackets are identical and can be installed on either side of
the chassis.
With the heads of the five chassis locating pins protruding though the five
keyhole openings in the mounting bracket, pull the mounting bracket toward the
front of the chassis until the mounting bracket clip locks into place with an
audible click.
Verify that the rear locating pin has engaged the mounting bracket
clip.
Repeat Steps 1 through 3 to install the remaining mounting bracket on the
other side of the server.
