Go to main content
Oracle® Server X5-4 Installation Guide
Exit Print View
Updated: July 2017
Rack Compatibility
This section describes rack compatibility considerations.
Check that your rack is compatible with the slide-rail and cable management arm (CMA) options. The optional slide-rails are compatible with a wide range of equipment racks that meet the standards shown below:
  • The rack must be a four-post rack (mounting at both front and rear). Two-post racks are not compatible.
  • Rack horizontal opening and unit vertical pitch must conform to ANSI/EIA 310-D-1992 or IEC 60927 standards. Only M6 tapped or 9.5 mm square holes are supported.
  • The distance between front and rear mounting planes must be a minimum 610 mm and maximum 915 mm (24 inches to 36 inches).
  • Clearance depth in front of front mounting plane (distance to front cabinet door) is at least 25.4 mm (1 inch).
  • Clearance depth behind front mounting plane (distance to rear cabinet door) is at least 900 mm (35.5 inches) with the cable management arm, or 770 mm (30.4 inches) without the cable management arm.
  • Clearance width between front and rear mounting planes (distance between structural supports and cable troughs) is at least 456 mm (18 inches).
  • Server dimensions:
    • Depth: (not including PSU ejectors): 732 mm (28.8 inches).
    • Width: (not including ears): 436.5 mm (17.2 inches).
    • Height: 129.9 mm (5.1 inches).
