This procedure provides instructions for connecting power cords to the back of the server.
Before You Begin
Ensure that all physical, electrical, environmental, and ventilation specifications and guidelines are met before powering on the server to standby power mode (see Server Specifications, Guidelines, Checklists).
For electrical specification information, see Electrical Specifications.
In the following illustration, call out 1 and call out 2 show the location of the PSU AC inlets. The PSUs are on the left side of the server and designated from left to right. The leftmost PSU is PS0 (call out 1), and the rightmost PSU is PS1 (call out 2).
Ensure that the cables do not interfere with the movement of the server when it is slid in and out of the rack.
As shown in the following illustration, the PSU has a panel with three indicators arranged in a single row from left to right: the leftmost green AC indicator (call out 1), a green OK indicator (call out 2), and the rightmost amber Service Action Required indicator (call out 3).
These indicators report on the state of the PSU as follows:
AC: Lights green when the AC power from the outlet is within specification for the PSU. The indicator does not light if the supplied power is insufficient.
OK: Lights green when the PSU is functioning properly and supplying the necessary voltages (AC and DC) for the server.
Service Action Required: Lights amber when the PSU is in a fault state. The server front panel Service Action Required indicator lights as well.
Next Steps
