Go to main content
Oracle® Server X5-4 Installation Guide
Exit Print View
Updated: July 2017
Safety Precautions
This section describes safety precautions you must follow when installing the server into a rack.
Caution
Caution  -  Equipment damage or personal injury. Always load equipment into a rack from the bottom up so that the rack does not become top-heavy and tip over. Deploy your rack's anti-tip bar to prevent the rack from tipping during equipment installation.
Caution
Caution  -  Elevated operating ambient temperature. If the server is installed in a closed or multi-unit rack assembly, the operating ambient temperature of the rack environment might be greater than room ambient temperature. Therefore, consideration should be given to installing the equipment in an environment compatible with the maximum ambient temperature (Tma) specified for the server. For server environmental requirements, see Environmental Specifications.
Caution
Caution  -  Reduced airflow. Installation of the equipment in a rack should be such that the amount of airflow required for safe operation of the equipment is not compromised.
Caution
Caution  -  Equipment damage or personal injury. Mounting of the equipment in the rack should be such that a hazardous condition is not achieved due to uneven mechanical loading.
Caution
Caution  -  Circuit overloading. Consideration should be given to the connection of the equipment to the supply circuit and the effect that overloading of the circuits might have on over-current protection and supply wiring. Appropriate consideration of equipment nameplate power ratings should be used when addressing this concern.
Caution
Caution  -  Personal injury. Reliable earthing of rackmounted equipment should be maintained. Particular attention should be given to supply connections other than direct connections to the branch circuit (for example, use of power strips).
Caution
Caution  -  Equipment damage. Slide-rail mounted equipment is not to be used as a shelf or a work space.
