Go to main content
Oracle® Server X5-4 Installation Guide
Exit Print View
Updated: July 2017
Install Server Into the Slide-Rail Assemblies
This procedure provides instructions for installing the server, with mounting brackets attached, into the slide-rail assemblies that are mounted inside the rack.
Caution
Caution  -  Equipment damage or personal injury. This procedure requires a minimum of two people because of the weight of the server. Attempting this procedure alone could result in equipment damage or personal injury.
Caution
Caution  -  Equipment damage or personal injury. Always load equipment into a rack from the bottom up so that the rack does not become top-heavy and tip over. Extend your rack's anti-tip bar to prevent the rack from tipping during equipment installation.
  1. If available, enagage the rack anti-tip mechanism.
    Your rack might use a different type of anti-tip bar than the one shown in the following illustration. Refer to your rack documentation for instructions.
    image:Graphic showing the anti-tip bar extended.
    Caution
    Caution  -  Equipment damage or personal injury If your rack does not have an anti-tip bar, the rack could tip over.
  2. Push the slide-rails into the slide-rail assemblies in the rack as far as possible.
  3. Raise the server so that the rear ends of the mounting brackets are aligned with the slide-rail assemblies that are mounted in the rack.
  4. Insert the mounting brackets into the slide-rails, then push the server into the rack until the mounting brackets encounter the slide-rail stops (approximately 12 inches, or 30 cm).
    Caution
    Caution  -  Equipment damage or personal injury. When inserting the server into the slide-rail, ensure that both the top and bottom mounting lips of the mounting brackets are inserted into the slide-rail. The server should slide forward and backward easily if correctly installed. If the unit does not slide easily, ensure that each mounting lip is inserted properly. If the mounting brackets are not inserted properly, the unit might fall when removing it from the rack.
    image:Graphic showing how to insert the server with mounting brackets into the slide-rails.
  5. Simultaneously push and hold the green slide-rail release buttons on each mounting bracket while you push the server into the rack. Continue pushing until the slide-rail locks (on the front of the mounting brackets) engage the slide-rail assemblies.
    image:Graphic showing the server being pushed back into the rack.
    Caution
    Caution  -  Equipment damage or personal injury. Verify that the server is securely mounted in the rack and that the slide-rail locks are engaged with the mounting brackets before continuing.
