The fan modules are keyed to ensure that they are installed in the correct orientation.
            See Server System-Level Status Indicators for more information about identifying and interpreting system status indicators.
If you installed the fan module as part of another procedure, return to that procedure.
Otherwise, return the server to operation. See Returning the Server to Operation.
