If the server is in the extended maintenance position, use this procedure to return the server to the normal rack position.
As you push the server into the rack, verify that the cable management arm (CMA) retracts without binding.
You will hear an audible click when the server is in the normal rack position.
For installation instructions for the CMA, refer to Install the Cable Management Arm in Oracle Server X6-2L Installation Guide.
For instructions on reconnecting cables to the rear of the server, see Reconnect Power and Data Cables.
For detailed information on connecting cables to the rear of the server, refer to Rear Cable Connections and Ports in Oracle Server X6-2L Installation Guide.
