In the confirmation dialog box, select Yes to proceed and
exit the BIOS Setup Utility, or select No to stop the exit
process.
Note -
After modifying any BIOS settings and selecting Save Changes and
Exit from the Save & Exit Menu, the subsequent reboot might
take longer than a typical reboot where no settings were modified. The
additional delay is required to ensure that changes to the BIOS settings are
synchronized with Oracle ILOM.
