Exit Print View
The server has six USB ports for attaching supported USB 2.0–compliant devices. Two USB ports are on the rear panel, two USB ports are on the front panel, and two USB ports are located on the motherboard.
Rear Panel Components and Cable Connections
Disconnect Cables From the Server
Reconnect Power and Data Cables
