SNMP Trap:
sunHwTrapSensorNonCritThresholdExceeded
Oracle ILOM Event Message: Upper
noncritical threshold exceeded
Severity and Description: Minor; A
sensor has reported that its value has gone above an upper non critical
threshold setting or below a lower non critical threshold setting. This
generic 'sensor' trap is generated when the SNMP agent does not recognize
the component type.
The sunHwTrapThresholdType object indicates whether the threshold was an
upper or lower.
/SYS/VPS_CPUS
/SYS/VPS_MEMORY
SNMP Trap:
sunHwTrapSensorThresholdOk
noncritical threshold no longer exceeded
Informational; A sensor has reported that its value is in the normal
operating range. This generic 'sensor' trap is generated when the SNMP agent
does not recognize the component type.
/SYS/VPS_CPUS
/SYS/VPS_MEMORY
SNMP Trap: sunHwTrapMemoryFault
Oracle ILOM Event Message: event
fault.cpu.intel.quickpath.link_slow "The Quickpath Interconnect (QPI) link
is operating below normal speed."
Severity and Description: Major; A
memory component is suspected of causing a fault.
/SYS/MB
SNMP Trap:
sunHwTrapMemoryFaultCleared
Informational; A memory component fault has been cleared.
/SYS/MB
fault.cpu.intel.quickpath.unknown-errcode "An unknown error code from the
Quickpath Interconnect (QPI) reference code has been detected."
/SYS/MB
SNMP Trap:
/SYS/MB
fault.memory.intel.dimm.none "An invalid memory DIMM configuration has been
detected."
/SYS/MB
SNMP Trap:
detected."
/SYS/MB
fault.memory.intel.dimm.memtest-failed "All memory channels have been
disabled due to memory test failures."
/SYS/MB
SNMP Trap:
/SYS/MB
fault.memory.intel.dimm.quadrank-3rd-slot "A quad-rank memory DIMM has been
installed in the third slot of a memory channel."
/SYS/MB
SNMP Trap:
/SYS/MB
fault.memory.intel.dimm.ddr3u-unsupported "An unsupported DDR3 ultra low
voltage memory DIMM has been detected."
/SYS/MB
SNMP Trap:
/SYS/MB
fault.memory.intel.mrc.unknown-errcode "An unknown error code from the
Memory Reference Code (MRC) has been detected."
/SYS/MB
SNMP Trap:
/SYS/MB
fault.memory.intel.dimm.udimm-unsupported "An unbuffered memory DIMM (UDIMM)
has been detected."
/SYS/MB/P[0-x]/D[0-11]
SNMP Trap:
has been detected."
fault.memory.intel.dimm.sodimm-unsupported "An unsupported SODIMM has been
detected in system."
SNMP Trap:
fault.memory.intel.dimm.4gb-fused "An unsupported 4-gb memory DIMM has been
detected."
SNMP Trap:
detected."
fault.memory.intel.dimm.8gb-fused "An unsupported 8-gb memory DIMM has been
detected."
SNMP Trap:
detected."
fault.memory.intel.dimm.incompatible "A memory DIMM is incompatible with the
memory controller."
SNMP Trap:
memory controller."
fault.memory.intel.dimm.incompatible-maxranks "The number of ranks allowed
on a memory channel has been exceeded."
SNMP Trap:
fault.memory.intel.dimm.incompatible-quadrank "An invalid quad-rank memory
DIMM configuration has been detected."
SNMP Trap:
fault.memory.intel.dimm.numranks-unsupported "A memory DIMM with an
unsupported number of ranks has been detected."
SNMP Trap:
fault.memory.intel.dimm.speed-slow "A memory DIMM has been detected that is
unable to run at speeds required by the platform."
SNMP Trap:
fault.memory.intel.dimm.disable-quadrank "Memory channel is populated with
too many quad-rank memory DIMMs."
SNMP Trap:
fault.memory.intel.dimm.population-invalid "Memory DIMM is improperly
populated or is a type that is not compatible with other DIMMs
installed."
SNMP Trap:
installed."
fault.memory.intel.dimm.out-of-order "The memory DIMMs in a channel are not
populated in sequential order."
SNMP Trap:
fault.memory.intel.dimm.category-unknown "Memory DIMM is of an unknown type
or category."
SNMP Trap:
or category."
