Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Oracle ILOM General System Targets and Properties
Oracle ILOM Fan Targets and Properties
Oracle ILOM Indicator Targets and Properties
Oracle ILOM Power Supply Targets and Properties
Oracle ILOM Temperature Targets and Properties
Oracle ILOM Voltage Targets and Properties
Oracle ILOM Voltage State Targets and Properties
Oracle ILOM General Targets and Properties
Oracle ILOM Service Targets and Properties
Oracle ILOM User and Session Targets and Properties
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
This table lists the Oracle ILOM targets supported in the gateway and provides a short description of the target.
