Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Displaying Information About Nodes
Identify All Switches in the Fabric
Identify All CAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display the Link Status of a Node
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Displaying Fabric Functionality Configuration Information
Display the InfiniBand Fabric Partition Configuration
Display the InfiniBand Fabric Configuration
Display the Fabric Element Configuration
Display Configured Secret M_Keys
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Disable or Enable an External Port
Partitioning the InfiniBand Fabric
smpartition Command Guidelines
Determine the Partitions and P_Keys
Add or Remove a Port From a Partition
Remove User Partitions for Firmware Downgrade
Create a Fabric Element Configuration
Add or Delete an Element From the Configuration
Modify an Element of the Configuration
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
You can manually set the speed of a single port to help determine symbol error generation. The ibportstate command can set the speed to 2.5, 5.0, or 10.0 Gbit/sec.
Note - If secret M_Key functionality is enabled, use the -M m_key option to the ibportstate command for external ports.
FabMan@gateway_name->ibportstate [-M m_key] lid port speed speed
where:
m_key is the management key (16 hexadecimal digits)(optional)
lid is the LID of the node.
port is the port of the node.
speed is the signaling rate per lane of the port (there are 4 lanes per port): 1 for 2.5 Gbit/sec, 2 for 5.0 Gbit/sec, and 4 for 10.0 Gbit/sec.
Note - Adding speed values enables either speed. For example, speed 7 is 2.5, 5.0, and 10.0 Gbit/sec.
For example:
FabMan@gateway_name->ibportstate 15 23 speed 1 Initial PortInfo: # Port info: Lid 15 port 23 LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps After PortInfo set: # Port info: Lid 15 port 23 LinkSpeedEnabled:................2.5 Gbps FabMan@gateway_name->ibportstate 15 23 speed 7 Initial PortInfo: # Port info: Lid 15 port 23 LinkSpeedEnabled:................2.5 Gbps After PortInfo set: # Port info: Lid 15 port 23 LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps FabMan@gateway_name->
Gateway Reference, ibportstate command
