| Critical Platform Alarms |
| 1000000000002000 - Uncorrectable ECC Memory Error |
0370 |
| Major Platform Alarms |
| 32300 3000000000000001 – Server Fan Failure |
0372 |
| 32301 3000000000000002 - Server Internal Disk Error |
0372 |
| 32303 3000000000000008 - Server Platform Error |
0372 |
| 32304 3000000000000010 - Server File System Error |
0372 |
| 32305 3000000000000020 - Server Platform Process Error |
0372 |
| 32307 3000000000000080 - Server Swap Space Shortage Failure |
0372 |
| 32308 3000000000000100 - Server Provisioning Network Error |
0372 |
| 32309 3000000000000200 – Server Eagle Network A Error |
0372 |
| 32310 3000000000000400 – Server Eagle Network B Error |
0372 |
| 32311 3000000000000800 – Server Sync Network Error |
0372 |
| 32312 3000000000001000 - Server Disk Space Shortage Error |
0372 |
| 32313 3000000000002000 - Server Default Route Network Error |
0372 |
| 32314 3000000000004000 - Server Temperature Error |
0372 |
| 32315 3000000000008000 – Server Mainboard Voltage Error |
0372 |
| 32317 3000000000020000 - Server Disk Health Test Error |
0372 |
| 32318 3000000000040000 - Server Disk Unavailable Error |
0372 |
| 32321 3000000000200000 – Correctable ECC Memory Error |
0372 |
| 32334 3000000400000000 - Multipath Device Access Link Problem |
0372 |
| 3000000800000000 – Switch Link Down Error |
0372 |
| 32336 3000001000000000 - Half-open Socket Limit |
0372 |
| 32337 3000002000000000 - Flash Program Failure |
0372 |
| 32338 3000004000000000 - Serial Mezzanine Unseated |
0372 |
| Major Application Alarms |
| 4000000000000001 - Mate EPAP Unavailable |
0373 |
| 4000000000000002 - RTDB Mate Unavailable |
0373 |
| 4000000000000004 - Congestion |
0373 |
| 4000000000000008 - File System Full |
0373 |
| 4000000000000010 - Log Failure |
0373 |
| 4000000000000020 - RMTP Channels Down |
0373 |
| 4000000000000040 - Fatal Software Error |
0373 |
| 4000000000000080 - RTDB Corrupt |
0373 |
| 4000000000000100 - RTDB Inconsistent |
0373 |
| 4000000000000200 - RTDB Incoherent |
0373 |
| 4000000000001000 - RTDB 100% Full |
0373 |
| 4000000000002000 - RTDB Resynchronization In Progress |
0373 |
| 4000000000004000 - RTDB Reload Is Required |
0373 |
| 4000000000008000 - Mate PDBA Unreachable |
0373 |
| 4000000000010000 - PDBA Connection Failure |
0373 |
| 4000000000020000 - PDBA Replication Failure |
0373 |
| 4000000000040000 - RTDB DSM Over-Allocation |
0373 |
| 4000000000080000 - RTDB Maximum Depth Reached |
0373 |
| 4000000000100000 - No PDBA Proxy to Remote PDBA Connection |
0373 |
| 4000000000200000 - DSM Provisioning Error |
0373 |
| 4000000000800000 - EPAP State Changed to UP |
0373 |
| 4000000004000000 - RTDB Overallocated |
0373 |
| 4000000020000000 - Mysql Lock Wait Timeout Exceeded |
0373 |
| Minor Platform Alarms |
| 32500 5000000000000001 – Server Disk Space Shortage Warning |
0374 |
| 32501 5000000000000002 – Server Application Process Error |
0374 |
| 5000000000000004 - Server Hardware Configuration Error |
0374 |
| 32506 5000000000000040 – Server Default Router Not Defined |
0374 |
| 32507 5000000000000080 – Server Temperature Warning |
0374 |
| 32508 5000000000000100 – Server Core File Detected |
0374 |
| 32509 5000000000000200 – Server NTP Daemon Not Synchronized |
0374 |
| 32511 5000000000000800 – Server Disk Self Test Warning |
0374 |
| 32514 5000000000004000 – Server Reboot Watchdog Initiated |
0374 |
| 32518 5000000000040000 – Platform Health Check Failure |
0374 |
| 32519 5000000000080000 – NTP Offset Check Failed |
0374 |
| 32520 5000000000100000 – NTP Stratum Check Failed |
0374 |
| 325295000000020000000 – Server Kernel Dump File Detected |
0374 |
| 325305000000040000000 – TPD Upgrade Failed |
0374 |
| 325315000000080000000– Half Open Socket Warning |
0374 |
| 5000000100000000 – Server Upgrade Pending Accept/Reject |
0374 |
| Minor Application Alarms |
| 6000000000000001 - RMTP Channel A Down |
0375 |
| 6000000000000002 - RMTP Channel B Down |
0375
| 6000000000000008 - RTDB 80% Full |
0375 |
| 6000000000000010 - Minor Software Error |
0375 |
| 6000000000000020 - Standby PDBA Falling Behind |
0375 |
| 6000000000000040 - RTDB Tree Error |
0375 |
| 6000000000000080 - PDB Backup failed |
0375 |
| 6000000000000100 - Automatic PDB Backup failed |
0375 |
| 6000000000000200 - RTDB Backup failed |
0375 |
| 6000000000000400 - Automatic RTDB Backup failed |
0375 |
| 6000000000001000 - SSH tunnel not established |
0375 |
| 6000000000002000 - RTDB 90% Full |
0375 |
| 6000000000004000 - PDB 90% Full |
0375 |
| 6000000000008000 - PDB 80% Full |
0375 |
| 6000000000010000 - PDB InnoDB Space 90% Full |
0375 |
| 6000000000040000 - RTDB Client Lagging Behind |
0375 |
| 6000000000080000 - Automatic Backup is not configured |
0375 |
| 6000000000100000 - EPAP QS Replication Issue |
0375 |
| 6000000000200000 - EPAP QS Lagging Behind |
0375 |
| 6000000000400000 - License capacity is not configured |
0375 |
| NOTE: The order within a category is not significant. |
