To service the system, you need the following tools:
No. 2 Phillips screwdriver
Anti-static wrist strap
ESD mat and grounding strap
You might also need a system console device, such as one of the following:
PC or workstation with RS-232 serial port
ASCII terminal
Terminal server
Patch panel connected to a terminal server
