What type of switch is this?
表示された項目から選択
Do you want to enable a strong password configuration?
Yes/No
If yes, what is the minimum number of characters in the password?
1 - 8
If yes, what is the minimum number of lower case letters in the password?
1 - 8
If yes, what is the minimum number of digits in the password?
1 - 8
If yes, what is the minimum number of special characters in the password?
1 - 8
If yes, what is the minimum number of upper case letters in the password?
1 - 8
What is the password for the admin user?
admin パスワードを入力します
What is the OSDN MAC address?
表示された項目から選択
